Different result with different machines?
Tsubasa
Post by Tsubasa »
I wonder simulation results are different if machines are different.
I run two simulations with the completely same setting.
Surprisingly the results are not identical at all.
I run 12000step, and in the first 50steps the results are the same as each other.
Is it true?
I think a very very small difference (less than 0.0001) accumulated over the 12000step and caused a big difference finally.
You can see the same results in step1 but different results in step12000.
Step1
Machine1
 INSTANT    0.100000000E+00   TIME STEP NUMBER               1
 ** Valeurs calculées sur cellules
   criterion               minimum         maximum   moy. ensemble   moy. spatiale
   Courant/Fourier          3.1321          3967.8          204.92          10.034
Machine2
** Computed values on cells
   criterion               minimum         maximum        set mean    spatial mean
Step12000
Machine1
INSTANT    0.120000000E+03   TIME STEP NUMBER            12000
   Courant/Fourier        0.013982           310.3          8.8389          2.4452
Machine2
   Courant/Fourier       0.0090879          314.62          8.6604           2.369
Re: Different result with different machines?
Yes, this is quite common, and due to numerical sensitivity (linked to handling of round-off errors). To determine if there is a problem or not, you need to look a things in more detail :
Do you have fluctuations in the solution ? Probes are useful for this, and in many cases, generating and outputting time averages can be quite useful for this (if you take the example of LES computations, the instant results on two machiens or 2 time steps will change, but the statistics should remain similar).
