Error during reading a CGNS Mesh
Posted: Fri Jul 01, 2022 4:07 pm
by sofenkumarjena
Hi I am reading a CGNS mesh in code saturne. The listing file shows the following
Reading file: mesh_input
Finished reading: mesh_input
Before insertion of user-defined boundary
Number of cells: 1413441
Number of interior faces: 3757307
Number of boundary faces: 95602
Number of vertices: 1067901
After insertion of user-defined boundary
Number of interior faces: 0
Number of boundary faces: 7610216
Number of vertices: 9555581
Number of cells + halo cells: 1413441
Histogram of the number of interior faces per cell:
minimum value = 0
maximum value = 0
1 : [ 0 ; 0 ] = 1413441
Writing file: mesh_output
Finished writing: mesh_output
Renumbering mesh:
renumbering for cells:
pre-numbering: no renumbering
cells adjacent to ghost cells last: no
renumbering for interior faces:
cell adjacency pre-ordering: lowest id first
faces adjacent to ghost cells last: no
numbering: multipass
renumbering for boundary faces:
numbering: no shared cell across threads
Numbering for cells:
type: default
number of halo-adjacent elements: 1413441
Numbering for interior faces:
type: default
number of halo-adjacent elements: 0
Numbering for boundary faces:
type: default
number of halo-adjacent elements: 7610216
Matrix bandwidth for volume mesh : 0
Matrix profile/lines for volume mesh : 0
Mesh coordinates: minimum and maximum
X : -5.0000000e-01 5.0000000e-01
Y : -5.0000000e-01 5.0000000e-01
Z : 0.0000000e+00 5.0000000e-01
Mesh
And finally this gives error during run, with the following error message.
(out of 7514614)
has boundary condition type 0, center (-0.441231, 0.440864, 0.369643)
/home/skjena/code_satrune/code_saturne-5.3.4/src/base/cs_boundary_conditions.c:363: Fatal error.
Some boundary condition definitions are incomplete or incorrect.
For details, read the end of the calculation log,
or visualize the error postprocessing output.
1: 0x7fd4f75ad618 <cs_boundary_conditions_error+0x128> (libsaturne-5.3.so)
2: 0x7fd4f7c31d9b <__cs_c_bindings_MOD_boundary_conditions_error+0xe> (libsaturne-5.3.so)
3: 0x7fd4f76c5c16 <typecl_+0x31d> (libsaturne-5.3.so)
4: 0x7fd4f75774fe <condli_+0x7bd> (libsaturne-5.3.so)
5: 0x7fd4f76c38a7 <tridim_+0x378e> (libsaturne-5.3.so)
6: 0x7fd4f755b138 <caltri_+0x20e1> (libsaturne-5.3.so)
7: 0x7fd4f8a2ea70 <cs_run+0x580> (libcs_solver-5.3.so)
8: 0x7fd4f8a2e3df <main+0x13f> (libcs_solver-5.3.so)
9: 0x7fd4f72b5083 <__libc_start_main+0xf3> (libc.so.6)
10: 0x556a9422107e <_start+0x2e> (cs_solver)
Kindly Help me
Sofen
Re: Error during reading a CGNS Mesh
Posted: Fri Jul 01, 2022 7:03 pm
Did you follow the instructions in the error message ?
Did you first run in preprocessing mode and visualize the output, to make sure groups ate present ?
Please post the logs instead of copying/pasting to avoid missing information (see Forum recommandations).
