avail a user created field for post processing
Posted: Mon Jun 13, 2022 2:39 pm
I have created a field using the function cs_field_create("xyz", field_type, CS_MESH_LOCATION_CELLS, 6, has_previous); in cs_user_parameters.c file. I can able to access the field in cs_user_source_terms.c file and perform necessary computation. However at the end of the run, these fields are not available for post processing in para view. To avail these field for post processing, I used the following functions.
const int k_post = cs_field_key_id("xyz");
cs_field_t *f1 = cs_field_by_name("xyz");
cs_field_set_key_int_bits(f1, k_post, CS_POST_ON_LOCATION);
In which field I can use these function to avail the desired field for processioning ? A minimal working example will be helpful.
With Regards
Sofen
With Regards
Sofen
