Page 2 of 2
Re: Spatially varying body force
Posted: Thu Mar 03, 2022 9:33 am
Reading this on my phone, while commuting, so I may have missed details, but tyour general approach seems good (MEDCoupling fields and code_satirne fields are different objects, so you need to transfer data from the first to the second).
Do you have the error at the first or second time step ? If it is at the second one, it could be due to an outgoing flow at an inlet (that could be caused by the source term). In this case, multiplying the source term by zero (for a test) but leaving the rest of the code as is could confirm this.
Otherwise, you might have an incorrectly defined dimension leading to a memory overwrite. Running under Valgrind would help check this.
Posted: Mon Mar 07, 2022 2:15 am
by ywan459
Thanks for your time!
After a few trail-error tests and read of reference codes, I moved my field declare to a different routine,
void
cs_user_model(void)
cs_parameters_add_variable("VectorFieldonNode", 1);
And the error message disappeared, the results seems fine now. Now I have Medcoupling issue - the error message showed
/home/App/code_saturne/code_saturne-7.0.2/src/base/cs_medcoupling_remapper.cxx:635: Fatal error.
Error: This function cannot be called without MEDCoupling support.
I will try to install MEDcoupling.
Posted: Mon Mar 07, 2022 11:27 am
The simples way to install MEDCoupling is probably to install a SALOME platform binary. DEpending on the SALOME build, the parallel features of MEDCoupling may be available or not, but in this case, If I recall correctly, only the base features (including MED file I/O) are needed, so a binary from the salome-platfor.org site should do, if your OS in in the list of proposed binaries.
Using the --with-salome =<path> option in the code_saturne configure should then find the contained MEDCoupling paths.
Posted: Tue Mar 08, 2022 2:39 am
by ywan459
Thanks for the advise!
I have installed salome on my drive. It works fine. My OS is Windows Linux Subsystem with Ubuntu 20.14. This subsystem works well with code_saturne before. I have successfully completed a few regular CFD modelling, and results looks promising.
To configure, I have ran the command line:
/App/code_saturne/code_saturne-7.0.2$ ./configure --with-salome=/home/App/salome/SALOME-9.8.0-native-UB20.04-SRC/BINARIES-UB20.04
Here is a piece of showed message:
OpenMP Fortran support: yes
CUDA support: no
BLAS (Basic Linear Algebra Subprograms) support: no
ParMETIS (Parallel Graph Partitioning) support: no
METIS (Graph Partitioning) support: no
PT-SCOTCH (Parallel Graph Partitioning) support: no
SCOTCH (Graph Partitioning) support: no
CCM support: no
HDF (Hierarchical Data Format) support: no
CGNS (CFD General Notation System) support: no
MED (Model for Exchange of Data) support: no
[b]MEDCoupling support: no[/b]
Catalyst (ParaView co-processing) support: no
Melissa (in-situ statistics) support: no
EOS support: no
freesteam support: no
CoolProp support: no
PETSc support: no
MUMPS support: no
AMGX support: no
Dynamic loader support: dlopen
Auto load environment modules: no
PdfLaTeX (document typesetting) available: no
Doxygen (document generation) available: yes
dot (Graphviz) available: yes
MathJax enabled: no
The package has been configured. Type:
make
make install
To generate and install the Code_Saturne kernel
You could see it showed
no medcoupling support. Then I just did regular make and install as hits showed:
and
I have also tried the --enable-medcoupling option in the configure command, it led to the error in make command.
I still have no lucky to run my model. same error message.
/home/yikun/App/code_saturne/code_saturne-7.0.2/src/base/cs_medcoupling_remapper.cxx:635: Fatal error.
After configure command, what should I do? Thanks in advance.
P.S. the other thing that confused me is the interpolation. I have data at nodes, but code_Saturne requires the data at "cell", how do I suppose to get the interpolated values from nodes to cell? I only see an example:
https://www.code-saturne.org/documentat ... er_3d.html This example seems directly take the cell field values. Does medcoupling interpolate values from nodes to cell?
ywan459
Posted: Tue Mar 08, 2022 9:29 am
The MEDCoupling detection (once SALOME is found) might have been broken by changes in SALOME distribution directory structures or environment variables. In this case, search for a file named MEDCoupling.hxx in the SALOME tree, and if you find it, use the part of its path before "include" with the --with-medcoupling=<path> code_saturne configure option.
Hoping this will work. Otherwise, if this fails, you can compile MEDCoupling from sources, using the same MED file support with medCoupling and code_saturne so that files can be read.
Regarding vertex/cells interpolation, I think MEDCoupling should handled that, and there are options to tune the algorimth choice for that.
Posted: Tue Mar 08, 2022 10:43 am
by ywan459
Thanks!
I have to give up on medcoupling with code_saturne. But I have coded the user subroutine in a different way that reads the txt file of the spatially varying body force and add it to NS equation. I found the way of interpolate the "cell value" from the nodal values through medcoupling in salome environment. Since it is not a variable, but a volumetric condition, I am happy about my current approach of direct export and direct read in.
I have to move on, and will come back to this point at some stage.
Now I have a new issue
I found the my model results (under the z direct universal body force) has a bit of discrepancy compared with the benchmark which the body force was set through GUI. Here is my final source term code:
void
cs_user_source_terms(cs_domain_t *domain,
int f_id,
cs_real_t *st_exp,
cs_real_t *st_imp)
/* field structure */
const cs_field_t *f = cs_field_by_id(f_id);
/* mesh quantities */
const cs_lnum_t n_cells = domain->mesh->n_cells;
const cs_real_t *cell_f_vol = domain->mesh_quantities->cell_vol;
/* Density */
const cs_real_t *cpro_rom = CS_F_(rho)->val;
const cs_real_t ro0 = cs_glob_fluid_properties->ro0;
cs_real_t *cvar_svbf_x = cs_field_by_name("x")->val;
cs_real_t *cvar_svbf_y = cs_field_by_name("y")->val;
cs_real_t *cvar_svbf_z = cs_field_by_name("z")->val;
if (strcmp(f->name, "velocity") == 0) {
cs_real_3_t *_st_exp = (cs_real_3_t *)st_exp;
/* apply source terms to all cells */
for (cs_lnum_t i = 0; i < n_cells; i++) {
_st_exp[i][0] = cell_f_vol[i] * cvar_svbf_x[i] * cpro_rom[i];
_st_exp[i][1] = cell_f_vol[i] * cvar_svbf_y[i] * cpro_rom[i];
_st_exp[i][2] = cell_f_vol[i] * cvar_svbf_z[i] * cpro_rom[i];
It reads the x, y and z components of acceleration from fields. In this case, x and y are 0, and z is 9.8 m/s^2. Then calculate the force_x = volume * acc_x * density, force_y = volume * acc_y * density, force_z = volume * acc_z * density.
I have attached the screen cuts of the total pressure. You may see the one subject to the GUI defined body force is higher than the one produced by my user code. Not sure the root cause, I guess the body force was implemented in a very different way ???
REgards
ywan459
Posted: Wed Mar 09, 2022 12:35 am
When defining a source term with the GUI, using a mathematical expression,, that expression is converted into C code in one of the cs_meg_*.c files you can find ind the "src" subfolder of computation run directories, then compiled along with user-defined routines.
It may be interesting to compare the expressions in those files to the one you programmed.
