Post-processing Pressure variables definition
Posted: Thu Dec 02, 2021 11:29 am
Could someone help me to understand the differences between both code_saturne output variables named : pressure and total_pressure ?
As I noticed, Pressure seems to be a relative static Pressure.
I would like to create a new variable, using Paraview, based on Pressure to obtain the same values as total_pressure.
If we check on code_saturne theory guide p.16 there is the following definition : P*=P − ρgx + 2/3ρk, where P* is the dynamic pressure field. I need some explanations because all these pressure definitions are not clear to me. Is P code_saturne computed static pressure
The aim of such topic is to understand each variables in order to create good additionnal pressure variables ( absolute pressure, dynamic pressure, etc.)
I want to define, for instance, the following variables :
*Relative Static Pressure
*Absolute Static Pressure
*Relative Dynamic pressure ( ρ*V²*0.5)
*Absolute Dynamic pressure ( ρ*V²*0.5)
*Relative Hydrostatic Pressure (ρ*g*h)
*Absolute Hydrostatic Pressure (ρ*g*h)
Thank you in advance for your help,
