Parallel computation issue with restart simulation
Rodolphe
Post by Rodolphe »
I am using the coupling between Saturne and Syrthès which works fine. When I use parallel computation and try to restart a new simulation from a previous one, I get an error linked to the .res file from the first simulation (It is not the case when I use simple computation). Indeed, it says that the the following file
resu1_00002part00000.res
cannot be opened whereas I did mention another .res file as results to begin from (resu1_all.res). The latter seems to hold results for the whole domain while resu1_00002part00000.res only a part (computed by one of the processors).
I've joined the .syd file of the failed case (untitled.log)and the listing files of both failed and previous case.
Thanks for your help !
Rodolphe
listing_previous.log
(115.5 KiB) Downloaded 13828 times
listing_failed.log
(4.87 KiB) Downloaded 13748 times
untitled.log
(3.34 KiB) Downloaded 13846 times
