Error without error files
Posted: Wed Mar 03, 2021 12:02 pm
by Tsubasa
I faced a problem.
Sometimes simulations stopped and some message appeared without error files.
There is no error files and no error message in calculation log.
Do someone know about this?
Tsubasa
Re: Error without error files
Posted: Thu Mar 04, 2021 1:28 am
Though this might not a defined by a norm, it seems many MPI environments use the signal number that crashed the compilation from a single process + 128 to define the returned signal number.
So 137 would be 128 + 9, meaning the computation is killed by signal 9 (same as "kill -9", see also /usr/include/bits/signum.h on must systems).
This signal cannot be intercepted, so the code does not have the time to write a backtrace.
This probably means you system or batch scheduler is killing the computation. It might have run out of allocated time.
If you have no batch scheduler (probably not on a simple virtual machine), if the memory requirements for the code exceed that allocated to the virtual machine, you might also have this error, or a cleaner stop, depending on how fast memory requirements grow. Not sure what other conditions can cause this.
