[MANJARO]Building trouble : linkage problem on syrthesppfunc
Josuez
Post by Josuez »
Hello Yvan and everyone
Hope you are doing good through these troubled times.
I went out of my comfort zone and looked for trouble as I tried to re-setup my working environment on a new system, so far one problem I don't know how to tackle has occurred.
A little bit of background : I am on the last version of Manjaro so Arch based, and using anaconda to manage python environments.
I am trying to build Syrthes4.3.5 after having successfully built Salome_mecaV2019.0.3 and Code_Saturne9.3.0, using salome_meca libraries for HDF5 CGNS MED and a python3.6.12 environment.
I attempt to build Syrthes4.3.5 using the automatic python installer.
As you understood from the title my problem occurs during the make call on syrthesppfunc
Konsole wrote: .
blablabla
- you ve chosen not to install "syrthescfd"
--> No precompiled GUI build /home/simulation/opt/syrthes4.3.5/src/syrthes-gui/exe.linux-x86_64
--> building GUI
Installation : generation of python files ...
function report
NO file ERREUR.log
Before using SYRTHES, each user must source
the /home/simulation/opt/syrthes4.3.5/arch/Linux_x86_64/bin/syrthes.profile file before using the code.
The easiest way is to put the following lines in each of the users
'.profile' or '.bashrc' (depending on the shell)
syrthesprofile=/home/simulation/opt/syrthes4.3.5/arch/Linux_x86_64/bin/syrthes.profile
#(adjust path to your system)
if [ -f $syrthesprofile ] ; then
. $syrthesprofile
fi
Warning : installation of some components failed
Check log files for more information....
ERREUR.log wrote: ../syrthesppfunc.log:collect2: error: ld returned 1 exit status
../syrthesppfunc.log:make[1]: *** [Makefile:15: a.out] Error 1
../syrthesppfunc.log:make: *** [Makefile:40: ppfunc] Error 2
syrthesppfunc.log wrote: mkdir: missing operand
Try 'mkdir --help' for more information.
make -I /home/simulation/opt/syrthes4.3.5 -C ./syrthes-ppfunc/src clean
make[1]: Entering directory '/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/src'
rm -rf /home/simulation/opt/syrthes4.3.5/build//*.o
make[1]: Leaving directory '/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/src'
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_cini.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_clim.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_clim_hmt.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_cphy.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_cphy.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_cvol.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_ecrire_vide.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_ecrire_vide.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_manip_chaine.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_manip_chaine.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_rescon.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o
ppfunc_cini.c: In function ‘cini_xx’:
ppfunc_cini.c:140:8: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
140 | rep_listint(list_ilist[numlist],&nb,ch+id+ifin);
ppfunc_rescon.c: In function ‘rescon’:
ppfunc_rescon.c:135:5: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
135 | rep_listint(list_ilist[numlist],&nb,ch+id+ifin);
ppfunc_clim.c: In function ‘clim_xx’:
ppfunc_clim.c:144:5: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
144 | rep_listint(list_ilist[numlist],&nb,ch+id+ifin);
ppfunc_cvol.c: In function ‘condvol_xx’:
ppfunc_cvol.c:148:8: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
148 | rep_listint(list_ilist[numlist],&nb,ch+id+ifin);
ppfunc_cphy.c: In function ‘lire_ecrire_prophy’:
ppfunc_cphy.c:116:4: warning: implicit declaration of function ‘extr_motcle_’ [-Wimplicit-function-declaration]
116 | extr_motcle_(motcle,ch,&i1,&i2);
ppfunc_clim_hmt.c: In function ‘clim_hmt_hhh’:
ppfunc_clim_hmt.c:140:5: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
ppfunc_cphy.c:124:13: warning: implicit declaration of function ‘rep_ch’ [-Wimplicit-function-declaration]
124 | ifin=rep_ch(list_formule_rho[numlist],ch+id);
ppfunc_cphy.c:176:8: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
176 | rep_listint(list_ilist[numlist],&nb,ch+id+ifin);
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_rescon_hmt.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o
gcc -c -O3 -D _FILE_OFFSET_BITS=64 -I/home/simulation/opt/syrthes4.3.5/src/syrthes-ppfunc/include ppfunc_syrthes.c -o /home/simulation/opt/syrthes4.3.5/build//ppfunc_syrthes.o
ppfunc_syrthes.c:59:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
59 | main(argc,argv)
ppfunc_syrthes.c: In function ‘main’:
ppfunc_syrthes.c:228:2: warning: implicit declaration of function ‘ecrire_vide_cini’; did you mean ‘ecrire_vide_cphy’? [-Wimplicit-function-declaration]
228 | ecrire_vide_cini();
| ecrire_vide_cphy
ppfunc_syrthes.c:241:2: warning: implicit declaration of function ‘ecrire_vide_prophy’; did you mean ‘ecrire_vide_cphy’? [-Wimplicit-function-declaration]
241 | ecrire_vide_prophy();
| ecrire_vide_cphy
ppfunc_syrthes.c:252:2: warning: implicit declaration of function ‘lire_ecrire_clim’; did you mean ‘lire_ecrire_chmt’? [-Wimplicit-function-declaration]
252 | lire_ecrire_clim();
| lire_ecrire_chmt
ppfunc_syrthes.c:296:2: warning: implicit declaration of function ‘ecrire_vide_cini_hmt’; did you mean ‘ecrire_vide_rescon_hmt’? [-Wimplicit-function-declaration]
296 | ecrire_vide_cini_hmt();
ppfunc_syrthes.c:308:2: warning: implicit declaration of function ‘ecrire_vide_chmt’; did you mean ‘ecrire_vide_cphy’? [-Wimplicit-function-declaration]
308 | ecrire_vide_chmt();
| ecrire_vide_cphy
ppfunc_syrthes.c:321:2: warning: implicit declaration of function ‘ecrire_vide_condvol_hmt’; did you mean ‘ecrire_vide_condvol’? [-Wimplicit-function-declaration]
321 | ecrire_vide_condvol_hmt();
| ecrire_vide_condvol
ppfunc_syrthes.c: In function ‘quel_model’:
ppfunc_syrthes.c:429:12: warning: implicit declaration of function ‘rep_int’ [-Wimplicit-function-declaration]
429 | model=rep_int(ch+i2+1);
ppfunc_rescon_hmt.c: In function ‘rescon_hmt’:
ppfunc_rescon_hmt.c:145:5: warning: implicit declaration of function ‘rep_listint’ [-Wimplicit-function-declaration]
145 | rep_listint(list_ilist[numlist],&nb,ch+id+ifin);
gcc -o /home/simulation/opt/syrthes4.3.5/arch/Linux_x86_64/bin/syrthes-ppfunc -O3 -D _FILE_OFFSET_BITS=64 /home/simulation/opt/syrthes4.3.5/build//*.o -lm
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0xcd540): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0xcd140): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0xcd940): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0xc3500): multiple definition of `list_ilist'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x0): multiple definition of `list_condi'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0xaae60): multiple definition of `list_formule'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0xcd540): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0xcd140): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0xcd940): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x927c0): multiple definition of `list_formule1'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x927c0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0xc3500): multiple definition of `list_ilist'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x0): multiple definition of `list_condi'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x7a120): multiple definition of `list_formule2'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x7a120): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x186a0): multiple definition of `list_formule6'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x30d40): multiple definition of `list_formule5'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x493e0): multiple definition of `list_formule4'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x493e0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0x61a80): multiple definition of `list_formule3'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x61a80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim.o:(.bss+0xaae60): multiple definition of `list_formule'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cphy.o:(.bss+0x147800): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cphy.o:(.bss+0x147400): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cphy.o:(.bss+0x147c00): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cphy.o:(.bss+0x13d7c0): multiple definition of `list_ilist'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cphy.o:(.bss+0x0): multiple definition of `list_condi'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x6bac0): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x6b6c0): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x6bec0): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x30d40): multiple definition of `list_formule1'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x927c0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x186a0): multiple definition of `list_formule2'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x7a120): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x61a80): multiple definition of `list_ilist'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x0): multiple definition of `list_condi'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_cvol.o:(.bss+0x493e0): multiple definition of `list_formule'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0xcd540): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0xcd140): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0xcd940): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x927c0): multiple definition of `list_formule1'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x927c0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x7a120): multiple definition of `list_formule2'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x7a120): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x61a80): multiple definition of `list_formule3'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x61a80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0xc3500): multiple definition of `list_ilist'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x0): multiple definition of `list_condi'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x186a0): multiple definition of `list_formule6'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x30d40): multiple definition of `list_formule5'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0x493e0): multiple definition of `list_formule4'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x493e0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon_hmt.o:(.bss+0xaae60): multiple definition of `list_formule'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x927c0): multiple definition of `list_formule1'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x927c0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0xc3500): multiple definition of `list_ilist'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0xcd540): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0xcd140): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0xcd940): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x0): multiple definition of `list_condi'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x186a0): multiple definition of `list_formule6'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x30d40): multiple definition of `list_formule5'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x30d40): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x493e0): multiple definition of `list_formule4'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x493e0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x61a80): multiple definition of `list_formule3'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x61a80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0x7a120): multiple definition of `list_formule2'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_clim_hmt.o:(.bss+0x7a120): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_rescon.o:(.bss+0xaae60): multiple definition of `list_formule'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x186a0): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_syrthes.o:(.bss+0x400): multiple definition of `ch'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3ad80): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_syrthes.o:(.bss+0x0): multiple definition of `chs'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3a980): first defined here
/usr/bin/ld: /home/simulation/opt/syrthes4.3.5/build//ppfunc_syrthes.o:(.bss+0x800): multiple definition of `motcle'; /home/simulation/opt/syrthes4.3.5/build//ppfunc_cini.o:(.bss+0x3b180): first defined here
But fromt there I don't know where to look to find the faulty linkage.
Other than that the gui is built without problems.
I have reduced the dependencies to the minimum for troubleshooting. Only the salome_meca HDF5 and MED libraries are called for the build and you can check the setup.ini file attached to this post.
I have tried to run a test case just in case but it also exits immediately on a [collect2: error: ld returned 1 exit status] error.
Have you ever seen this behavior ?
syrthesppfunc.log
(18.72 KiB) Downloaded 8537 times
ERREUR.log
(188 Bytes) Downloaded 8662 times
setup.ini
(4.04 KiB) Downloaded 8435 times
Re: [MANJARO]Building trouble : linkage problem on syrthesppfunc
Yes, I had a similar issue on Arch Linux, due to the more recent and picky tools.
In setup.ini, you can add linker options to work around this:
specific_lib= -Wl,--allow-multiple-definition
specific_option= -Wl,--allow-multiple-definition
Josuez
Post by Josuez »
As always thanks for the quick answer
I implemented your solution and this actually helped for some other problems that weren't highlighted during the installation.
As a result I can now run syrthes on test cases and get an output.
But syrthesppfunc still threw an error during the automatic installation, I haven't tested extensively but I suppose it will prevent me to define functions in my cases. This is the only module which fails to build.
I will attach the setup.ini and ERREUR.log
ERREUR.log
(188 Bytes) Downloaded 8621 times
setup.ini
(4.19 KiB) Downloaded 8458 times
Do you have any other part of the error message in which the missing library name might appear ?
I am not sure of what ppfunc is used for, so do not know if you will miss it or not.
michal777
Post by michal777 »
Hi, I probably have the same problem - can't compile and there are complaints about multiple definitions. I tried the workaround with --allow-multiple-definition in setup.ini but it didn't help.
I attach file resume. It looks like the problem starts in line 290 of the attached file
gcc -o /home/michal/build/syrthes5.0/arch/Linux_x86_64/bin/syrthes-ppfunc -O3 -D _FILE_OFFSET_BITS=64 -D_SYRTHES_MPI_ /home/michal/build/syrthes5.0/build//*.o -lm
So the issue may be in syrthes-ppfunc and the workaround with --allow-multiple-definition seems to be not working here.
setup.ini
(4.23 KiB) Downloaded 8498 times
resume.txt
(263.62 KiB) Downloaded 8389 times
Yes, I had a similar issue even with Syrthes 5 on recent distribs (On Debian 11 on my work machine. I have not compiled Syrthes on my home Arch-based system in a while...).
Fixing it basically requires modifying the code, adding "static" qualifiers on some variables to keep the deifnitions local (and then, the code is still ugly). I can try to upload a patched version of Syrthes 5 in the coming days, but that version also includes binary libraries for new dependencies, which should probably work, but couls cause issues. The additional libaries are under a GPL licence, and can be compiled, but that makes the build procedure more complex.
The Syrthes team should have the latest compilation patches I sent them a few days ago, so e-mailing Syrthes support so that they post an u to date version on the web would be a good idea... Hoping they integrated my patches and respond.... I'll remind them if I seem them this coming week...
JuanMiTC
Post by JuanMiTC »
Is there any update on this problem? I am experiencing very similar problems installing Syrthes 5.0 on Ubuntu 22 and would like to know if there has been any progress.
Regards and thanks.
JuanMiTC
Post by JuanMiTC »
Well, I don't know if it was inspiration at the time of writing the post but I found the solution. The reality is that it is quite simple.
Gcc >= 10 starts complaining about multiple definitions. The problem is solved with the -fcommon flag.
To do so, in setup.ini you have to write the following
specific_option= -fcommon
Unfortunately, Yvan's solution did not work for me.
