velocity non-zero in solid region with conjugate heat transfer in LES
Posted: Wed Jan 06, 2021 9:45 am
I'm running LES with internal coupling of solid-fluid conjugate heat transfer. I'm using version 6.0.5. I found in the solid region, the velocity is 0 in the x and y direction, but non-zero in z-direction. A picture showing the velocity distribution over the domain (one slice of the axisymmetric domain, solid region is an inner plate at the upper part of the domain) and a line plot of v_z in the solid region (a vertical line through the solid region, it shows v_z is about 0.0238). I also found in run_solver.log, N_iter for pressure can be as high as 2000 or above. Is that reasonable? cs_user_parameters.c is also attached.
Xiaoxue
Xiaoxue
