Creating new studies in a folder with the same name
Posted: Wed Oct 21, 2020 12:19 pm
It seems that one cannot explicitly create a new study if the study name is identical to the name of the current folder. Are there any plans for this to change, or is this behavior documented somewhere?
(Or could at least a warning be printed? -- it does not seem ideal from the user experience side if creating new studies magically works or does not work depending on the name given.)
Best,
Jeff
(Apologies if this is in the wrong section -- the two "Code_Saturne usage forum guidelines" links <viewtopic.php?f=2&t=7> are both broken...)
Best,
Jeff
