I use Tecplot for post-processing my CFD simulations.
When I load the results generated by Code_Saturne to Tecplot, there are no values available for velocity, pressure and Reynolds stresses on the boundaries and only mpi_rank_id and yplus are available.
I think It's because of the concept of the Finite Volume where calculations occur at the cell centers not nodes. But this issue does not occur in Results generated by Fluent.
Is there any way to have the values of the velocity, pressure and Reynolds stresses on the boundaries? I need them for calculating the lift and drag (shear stress) on a 3D wing. And also some turbulence parameters on other boundaries.
I also checked the results in Paraview and the same thing happens.
I mean something like the below image which is generated by Paraview from the results of OpenFoam.
Please keep in mind that I don't have access to GUI.
Thank you in advance for your great support which is one of the best that I've seen for free and open-source softwares.
Best Regards,
Mohammad
