What type of system/distribution are you running under the WSL ? The Python libraries are in /usr/lib most of the time, but I have never seen a system with the Python executabl in /usr/lib.
What does the "type python3" command return ?
Error with PyQt5
Re: Error with PyQt5
Thanks,
Its ubuntu 20.04 and "type python3" returns "python3 is hashed (/usr/bin/python3)"
Bineet
Bineet
so that is the value you need to define as python (in the automatic installer) or PYTHON= (in the lower-level "configure" options).
Things should then work. Do you have additional Python environments (such as CONDA) ? They can make a mess if you mix versions.
