Within an IFS calculation, I have remarked that displacement histories of the structures are not necessarily good written in parallel mode.
I performed some tests and I remarked that the good data are written within certain processes and spurious ones within other processes.
Therefore I created a script to overcome this problem. Nevertheless is it possible to find the problem and to correct that bug on your side ?
Thank you in advance for your attention.
So_nuc
Writing of histories in parallel mode (IFS calculation)
Re: Writing of histories in parallel mode (IFS calculation)
Which version of the code ? Do you have a small example case so we can reproduce, debug, and fix ?
Thank you for your reply. Sorry I have indeed forgotten to write that I am using V6.0.1. I have enclosed a test case.
Thank you in advance.
So_nuc
So_nuc
- TEST_CASE_CN1_V6.0_PAR.tar.gz
- (69.46 KiB) Downloaded 702 times
