Hi everyone !
I'm working on modeling aerosol transport using Diffusion Inertia Model. In the theory guide Section 2.3.1 (Equations for scalars with a drift), it is mentioned that details on theoritcal work and implemetation of the DIM model can be found in technical note H-I81-2013-02277-EN. So I'm wondering if anyone knows where I can found this technical note ?
thank you.
Re: Diffusion Inertia Model
The reference document is an internal EDF document, so I am not sure I can re-publish it on this forum.
It is mostly a validation test-case description, the theory being based mostly on P. Nérisson's PhD ("Modélisation du transfert des aérosols dans un local ventilé. Thèse de doctorat, Université de Toulouse, Toulouse"), which is in French.
If necessary, I'll check if I can publish some extracts of the document (the parts relative to the numerical model).
Thank you for your reply and for the refernce document.
