Sort the exported data in parallel mode
Mohammad
Post by Mohammad »
I want to export the u component of velocity field every 100 iterations to a file. I also write the coordinates of the cells in 3 columns.
So, I wrote the following codes in cs_extra_operations.cs file.
const cs_lnum_t n_cells = cs_glob_mesh-> n_cells;
cs_real_3_t *cvar_vel = (cs_real_3_t *)CS_F_(u)->val;
cs_real_3_t *cell_cen = mesh_quantities->cell_cen;
      if(fmod(ntcabs,5) == 0)
          for (cs_lnum_t i = 0; i < n_cells; i++) {
            FILE *f2 = NULL;
              f2 = fopen("VELOCITY_COMPONENTS","a");
              fprintf(f2, "%i\t%f\t%f\t%f\t%f\n", ntcabs, cvar_vel[i][0],cell_cen[i][0],cell_cen[i][1],cell_cen[i][2]);
              fclose (f2);
It does the job very well, but the problem is that the exported data is not sorted well when using parallel cpus.
The exported data are sorted randomly in parallel mode, while in single processor mode they are sorted very well by cell id.
Is there a way to sort the exported data in parallel mode like the ones in single processor mode?
Mohammad
Re: Sort the exported data in parallel mode
Did you look at the probes and profiles documentation ? It seems it would be adapted to what you are doing.
Otherwise, export to EnSight format, and extract the data to CSV using ParaView.
Mohammad
Post by Mohammad »
Thanks a lot.
I did it using cs_glob_mesh->global_cell_num and Linux's terminal sort command!
Mohammad
