ALE simulations: local fluid force on specific rigid body positions
daniele
Re: ALE simulations: local fluid force on specific rigid body positions
Post by daniele »
Dear Luciano,
Thanks a lot, you are right, the correct field is iforbr.
I am now able to calculate the Stress on the cell surfaces.
I still have one problem. In order to obtain the force, I have to multiply the Stress by the boundary surface of the cell.
The surface value is given by surfbn(ifac) if I am not wrong.
To check the consistency, I performed the following test to calculate the total boundary surface:
s_tot = 0.d0
 call getfbr('STRUCTURE_WALL', nlelt, lstelt)
    do ilelt = 1, nlelt
       ifac = lstelt(ilelt)
       s_tot=s_tot+surfbn(ifac)
    enddo
Post-processing "s_tot" at every time step, I always have s_tot=0.
Is surfbn the right field to get the face surface?
Daniele
Luciano Garelli
Post by Luciano Garelli »
You can check the user example cs_user_extra_operations-global_efforts.f90 file. You don't need to multiply by the face area.
Are you running in parallel or serial? Because if you run in parallel you have to do a parallel sum of this variable and the same for the forces.
daniele
Post by daniele »
I agree with you about the example.
Nevertheless, in code_saturne doxygen "iforbr" is described to be "field id of the stresses at boundary".
That's why I am confused. It looks as if iforbr was just mu*du_i/dx_i.
Moreover, are pressure forces taken into account inside iforbr?
I did a test to double check: I calculated the sum of iforbr (along a given direction) for the "internal coupling" wall. The obtained value is completely different from the one printed inside the "probes_str_force_i.dat".
I should maybe try to look inside the source what iforbr is exactly...
Have you ever used this field to postprocess forces?
Thank you very much!
Daniele
Luciano Garelli
Both are taken into account, pressure and viscous forces. You can check the file post_util.f90. In this file the forces are used to compute normal and tangential stresses to be the post-processed in salome.
Also I guess that in the forum there are several post about the force posprocessing.
daniele
Post by daniele »
Dear Luciano,
Thanks to your help, I managed to calculate the forces on the faces I wanted to.
Daniele
