Two propellers flow interaction
roberto.bernetti
Post by roberto.bernetti »
I'm going to model the interaction of the flow generated by two different propeller, rotating at different angular speed.
I suppose one has to use three meshes one for the environment, a cube for example, and the second and the third meshes for the two rotating propeller, rotating at different angular velocity.
Can, the moving capability of code_saturne, deal with two different rotating meshes at different rpm?
Last edited by roberto.bernetti on Tue Aug 06, 2019 4:00 pm, edited 1 time in total.
Saluti
Roberto
Re: Two propelles flow interaction
If you use the turbomachinery model of the code, yes, each rotor (propeller) can have a different rotation velocity.
