plot the pressure over a cylinder in ParaView or EnSight
Posted: Mon Jun 17, 2019 11:05 pm
by zakaria_rhm
hi,
how to plot the pressure over a cylinder in ParaView or EnSight ?
Re: plot the pressure over a cylinder in ParaView or EnSight
Posted: Tue Jun 18, 2019 7:43 am
Could you ne more specific ? Do you need to map the cylinder surface to a plane or simply view data ?
If you need to plot the cylinder to a plane I know there is a new filter for this I'm Paraviz (Paraview + additional plugins) I'm Salome 9.3, but am not sure it is in ParaView itself (and do not remember the name of the filter, just that it is not available in older versions).
As for EnSight, I have not used it these last few years, so although I remember there was a feature for this I could not explain how to access it).
Posted: Tue Jun 18, 2019 10:50 am
by zakaria_rhm
hello, maybe I have not given more details about my problem, the study is a numerical simulation of a turbulent flow around four cylinders in square configuration, I used Gmsh for geometry and mesh generation , then Code_Saturne for the calculation, what is I want exactly how to plot the pressure curves in functions of the angle (0 to 360) for each cylinder. I hope that I have explained what I want, thank you for your reply sir.
Posted: Tue Jun 18, 2019 12:46 pm
In this case I would recommend directly defining profiles in the code (either in the GUI, where you can define a curve as xyz = f(s), with the number of points of your choice, or in a user function). Doing it from the GUI, you would get the pressure at the centerof boundary cells rather than at the boundary, but an external tool like ParaView or Ensight would not have more information to work with so would not do better. With a user function, or the "new" plot system (
https://www.code-saturne.org/cms/sites/ ... bes_p.html) you can do better, though it requires a bit more work.
I recommend starting with the simple solution (GUI-defined profiles).
Posted: Wed Jun 19, 2019 7:09 pm
by zakaria_rhm
merci pour votre réponse, j'ai d'autre question sur les résultats obtenus par Code_saturne, comment assure que la solution numérique tende vers la solutions exacte (la convergence) ?
Posted: Fri Jun 21, 2019 3:38 pm
by zakaria_rhm
thank you for your answer, I have other question on the results obtained by Code_saturne, how ensures that the numerical solution tends towards the exact solutions (the convergence)?
Posted: Tue Jun 25, 2019 10:06 am
This is a very broad question.
The best practice guidelines on the web site (
https://www.code-saturne.org/cms/documentation/BPG) need to be updated ans expanded, but are still valid and explain what you should check for.
