VOF and ALE compatible?
Posted: Wed May 29, 2019 4:16 am
by ffan
Hi CS users,
Can VOF be used with ALE at the same time? For example, if the cylinder in the fluid-solid interaction tutorial case is immersed in a free surface flow, and the model requires VOF and ALE together. Thanks.
- ffan
Re: VOF and ALE compatible?
Posted: Thu May 30, 2019 1:38 pm
by Martin FERRAND
It should be compatible but we don’t have any validation test case for that so that would be nice if you could set up a toy model test case to check if it is working correctly.
If not, that will not be a big deal to fix (ALE is mainly impacting the other fields updating convective mass flux, if that is correct the rest should be ok).
Best Regards
Martin
Posted: Fri May 31, 2019 1:15 pm
by Luciano Garelli
VOF and ALE can be used simultaneously. I did some test with a wave generator.
Be careful with the version that you are using becouse were a bug fixed in the ALE Bc (commit 4b879fa).
Posted: Sat Jun 01, 2019 2:57 am
by ffan
Thank you Luciano.
- ffan
