Low value of Turbulent heat fluxes in Natural convection
kunalck
Post by kunalck »
Hello Everyone,
I am running Rayleigh Benard natural convection case with Rayleigh number to be 630000 and Pr as 0.71. I am using AFM as turbulent heat flux model. For boussinesq implementation, I am adding boussiesq(rho*beta*(T-t_ref)*g) source term in momentum equation.
I am facing an unusual problem regarding the turbulent heat flux magnitude. The turbulent heat fluxes for this case are incredibly low value(1e-38 to 1e-36). Whereas the temperature profiles are predicted well when compared to DNS results.
Also the turbulent kinetic energy (i.e. rij values) is also incredibly low.
Code_saturne v 5.1.3.
Turbulence model : RSM-EB
turbulent heat flux model : AFM
The attachment afm_dns.png is no longer available
Kindly suggest few changes.
Kunal
63e4_afm_data0.csv
(2.15 MiB) Downloaded 731 times
C0st4s
Re: Low value of Turbulent heat fluxes in Natural convection
Post by C0st4s »
May I asked how did you implement Boussinessq?
i.e cs_user_source_terms.f90 under ustsnv or cs_user_physical_properties.f90 under usphyv?
Cheers,
Costas
kunalck
Post by kunalck »
I used ' cs_user_source_terms.f90' under ustsnv for Boussinesq approximation.
Kunal
C.FLAG.
Post by C.FLAG. »
I have started a case with natural convection under 6.0-beta, Rij-SSG + AFM, the temperature / turbulent heat fluxes have a very high amplitude, 10e50. Switch back to 5.0 if you need results quickly. Otherwise, wait for fixes.
P.S.: tests performed with the temperature flagged as buoyant in cs_user_parameters.c and the SIMPLEC time scheme. Switching to PISO and nterup = 3 did not improve the situation.
void
cs_user_parameters(cs_domain_t   *domain)
  /* Declare the temperature as a buoyant scalar */
  cs_field_set_key_int(cs_field_by_name("temperature"),
                       cs_field_key_id("is_buoyant"),
                       1);
Cédric
Jean-Francois Wald
Post by Jean-Francois Wald »
kunalck wrote: Mon Apr 08, 2019 3:23 pm Hello Everyone,
63e4_afm_data0.csv
Kunal
Thank you for your feedback on the AFM model. Your temperature profile looks good probably because the GGDH part of the AFM works well whereas the additional terms ( bouyancy, velocity gradient,...) might be bugged.
Can you post your test case so that I can have a look ?
C0st4s
Post by C0st4s »
Thanks for the clarification. Another question if you do not mind. If you use Boussinesq through cs_user_source_terms.f90 under ustsnv what did you do with the gravity vector in the generation rate of turbulence (Gk)?
Cheers,
Costas
kunalck
Post by kunalck »
Jean-Francois Wald wrote: Tue Apr 09, 2019 12:54 pm
63e4_afm_data0.csv
Kunal
Hello Jean-Francois,
Thank you for your feedback. I have also run the same case with unsteady solver(CS_v4.0) and I could not prevent the laminarization. Although, temperature profile was like previous case(predicting well compared with DNS).
u_rbc1.xml
(10.66 KiB) Downloaded 783 times
Rbc_3_mesh.cgns
(1.2 MiB) Downloaded 796 times
kunalck
Post by kunalck »
C0st4s wrote: Thu Apr 25, 2019 10:55 am Hi,
Cheers,
Costas
I gave the value of gravity as a negative vector in GUI. And when using Boussinesq through cs_user_source_terms.f90, then the I would use gy for gravity.
kunalck
Post by kunalck »
Hello Everyone,
I am currently running Rayleigh Benard Natural Convection simulations. Ra 1e5 and Pr 0.025
I have encountered a strange error in temperature profile. I am noticing these rings along the plumes of upward flow i.e. Mushroom like structures in temperature contours. I have attached a plot of the temperature across the observed ring.
Also I would like to point out that the structures/ perturbations in temperature are observed only for Pr 0.025 cases. The rings/perturbations are no observed for Pr 0.7 or 0.006. Also I would like to add that the overall profile of the temperature on averaging across the domain along x-axis is slightly affected and can be observed only at a closer look. I just wanted to know what could be causing it and what can be done to avoid these in future ?
Heat flux model - AFM
Turbulence model - RSM:EB
unsteady RANS
Which version of the code are you using ? If you are not using version 6.0, I recommend upgrading, as you may
- either find a bug has been fixed
- help get a bug fixed (assuming it is a bug) in one of the next 6.0.z releases
while with older versions, only major bugs may be fixed (but if you have a regression relative to an older version, we do need to check that also).
Could you post your setup (without the mesh, unless it is small).
