Radiative Heat Transfer Problem
wenhao
Post by wenhao »
Dear all,
Does anyone has the manual on using the radiative heat transfer and conjugate heat transfer command in code saturne? I am doing the ventilation within shipping container house and would like to add the heat transfer through radiation in the calculation for better accuracy. Need your help. Thanks
Re: Radiative Heat Transfer Problem
How is this related to code development ? It seems this post should be moved to the "general usage" section, unless I do not understand your question.
