Problem Installing Salome 8.5 with Code_Saturne 5.0.9
Posted: Thu Oct 25, 2018 12:24 pm
First, I installed Salome 8.5.
It has been installed in the directory: "/home/mohammad/salome".
Then, I installed Code_Saturne 5.0.9 Autumatically and edited setup file to this one:
(Just edited the installation directory and Defined salome installation path)
Now, after the code_saturne is installed when I want to use "code_saturne salome" it says:
"SALOME is not available in this installation."
What's The Problem?
# Setup file for Code_Saturne installation
# Download packages ?
download yes
# Language
# default: "en" english
# others: "fr" french
language en
# Install Code_Saturne with debugging symbols
debug no
# Installation directory
prefix /home/mohammad/cfd/Code_Saturne/5.0.9
# Optional architecture Name (installation subdirectory)
use_arch no
arch Linux_x86_64
# C compiler and optional MPI wrapper
compC /usr/bin/cc
mpiCompC auto
# Fortran compiler
compF /usr/bin/f95
# C++ compiler and MPI wrapper for optional packages
# Required only for static builds using the MED library
# or for build of optional modules such as MEDCoupling
# support.
compCxx /usr/bin/c++
mpiCompCxx auto
# Python interpreter.
python /usr/bin/python
# Disable the Graphical user Interface ?
disable_gui no
# Disable frontend (also disables GUI) ?
# May be useful for debug builds and HPC cluster builds
# installed side-by side with a full build.
disable_frontend no
# Optional SALOME platform install path.
# This is the path for the main SALOME directory,
# not the application directory.
# If Code_Saturne is built with SALOME support,
# running "code_saturne salome" will launch the
# associated application, containing the CFDSTUDY module.
salome /home/mohammad/salome
# Optional packages:
# MED / HDF5 For MED file format support
# (used by SALOME and by Gmsh)
# CGNS / HDF5 For CGNS file support
# (used by many meshing tools)
# Scotch (includes PT-Scotch) and/or ParMetis
# for parallel partitioning
# For Linux workstations, HDF5, CGNS, and even MED
# packages may be available through the package manager.
# HDF5 is also often available on large systems.
# When building with SALOME, the platform distribution's
# packages may be used, by setting in the matching entry
# 'yes' under the "Use" column and simply 'salome' under
# the path column.
# Scotch and Pt-Scotch are available in some Linux
# distributions, but may be built with options
# incompatible with non-threaded Code_Saturne runs.
# To install CGNS or ParMetis, the CMake
# configuration/installation tool is required
# (it is available in most Linux distributions)
# Libxml2 is needed to read XML files output by the
# Graphical User Interface. It is generally available
# through the package manager.
# Name Use Install Path
hdf5 no no None
cgns no no None
med no no None
scotch no no None
parmetis no no None
libxml2 auto no None
#========================================================"SALOME is not available in this installation."
What's The Problem?
