[v5.0.4] Deactivate monitoring point output for user-defined time-averages
philippks
Post by philippks »
in version 5.0.4, how can I deactivate the monitoring output for specific user-defined time-averages, which I have defined before in cs_user_parameters.c? I have tried to set keyvis to POST_ON_LOCATION only (without POST_ON_MONITOR), but it didn't work.
Many thanks,
Philipp
Re: [v5.0.4] Deactivate monitoring point output for user-defined time-averages
You did not post your setup, so I cannot determine whether this is a user error or a bug. What you describe should work.
I recall fixing something which might be the cause of this issue some months ago, so you might want to check with version 5.0.9.
