problem using a 3D extruded mesh with periodic boundary condition
lzhang
Post by lzhang »
I have a test case involving the simulation of flow around a cylinder. For this test, I use 3D meshes extruded from a 2D one. For the first mesh with 10 cells in the z direction, when I run the simulation I got an error "*** Error in `./cs_solver': malloc(): memory corruption: 0x0000000001784ed0 ***". However the number of cells is not that large (about 270000 cells) to have a memery allocation problem. For the second mesh with 4 cells in the z direction, I got a different error "Cannot achieve to reorient the current joined face with face 45313 (selected face)."
The boundary condition for faces ("front", "back") whose normal is in Z direction is set to be periodic. Certainly, the periodic boundary conditions are not well set, since If I use Symmetry type for these two faces, I have no more previous errors.
Could you please tell me what is going wrong in the periodic BC setting, please? I'm using code_saturne 5.0.4, and in attached file you can find the .xml file, mesh files and the listing files.
Lei
listing_case2.txt
(14.23 KiB) Downloaded 453 times
listing_case1.txt
(14.9 KiB) Downloaded 448 times
case_mesh1.zip
(5.89 MiB) Downloaded 468 times
lzhang
Re: problem using a 3D extruded mesh with periodic boundary condition
Post by lzhang »
I add also .xml file and the mesh file for test case 2 (4 cells in Z direction).
case_mesh2.zip
(2.93 MiB) Downloaded 410 times
There was a fix in version 5.0.6 in parallel mesh extrusion (which occured when some ranks had no boundary faces), so could you test if you still have this crash with version 5.0.6 or more (5.0.9 bug-fix was released today, so I recommend that one).
lzhang
Post by lzhang »
Maybe I was not well explaining my problem. I did not use mesh extrusion of code_saturne to build mesh, in fact the extruded mesh was already built with salomé. So I think it is a problem related to periodic boundary condition.
I will test the version 5.0.9 and let you know if the problem is solved.
Best regard,
Lei
lzhang
Post by lzhang »
I just tested the 5.0.9 version, and I encountered the same error.
Certainly, it is due to the BC boundary condition. Do you have any ideas to solve it, please?
Lei
I checked the first case, and it seems you defined the periodicty incorrectly: your mesh has a z range of [0, 0.07456], so your periodicity in z should be 0.07456, not 1 (it is not just the direction, but also the distance).
With the correct value, things seem OK. I assume the issue in the second case is due to similar causes (I'll let you re-check).
lzhang
Post by lzhang »
Indeed it was a problem with the translation vector.
All works now!
Thanks a lot!
Lei
