possibility of multiple Code_Saturne instances coupling?
Posted: Thu Sep 20, 2018 5:31 pm
I would like to know if it is possible to perform a multiple Code_Saturne instances coupling. My problem setting is as follows: For each instance, I will have an oscillating cylinder interacting with the fluid (it is a 2D simulation, as there is only one cell in the z direction). Then the instances will be coupled via le movement of the cylinder (transfer of displacement and velocity between instances), as if the cylinders were connected each other by springs. There is no interaction between each instance via the fluid domain.
I would like to know if it is conceptually possible to do this kind of simulation with Code_Saturne? I think at least for 2 instances coupling, this should be possible, one need to define the interface condition such that there is no exchange of pressure and velocity, but exchange of some additional variables (cylinder displacement and velocity).
Could you please tell me if what I have described here is possible (perhaps with a lot of code modifications) ? Or maybe there are other ideas to do this kind of simulation without using code coupling, as there are no exchange of physical quantities of fluid here.
Thanks!
Lei
Thanks!
Lei
