Dear all,
I am facing an issue regarding a parallel batch job.
The batch system is SGE.
Although in my script there is the option to run my job in parallel: #$ -l nodes=2, once the job starts running is still serial!
I also tried to add --mpi at the call to run the job; in my case:
/scratch/hpc/25/attene/CS_wave_loads/73_steady_conformal/3.62/RESU/20180808-0022/run_solver --mpi
with or without --mpi the calculation behaves the same.
any idea?
I was thinking this issue may be due to the configuration of the batch system during the post installation...
regards,
FA
parallel batch job
Re: parallel batch job
How are you submitting the job ? What is in your "run_solver" script (generated in RESU/<run_id> before running) ?
Do you have any messages when submitting ? Or in the batch log files ?
I have attached the run_solver as well as the performance.log and setup.log.
I didn't have any particular messages when submitting neither in the batch log files.
At the moment I am waiting for a simulation to start: I added mpirun at the line of the command of cs_solver in the run_solver.
FA
FA
- setup.log
- (25.7 KiB) Downloaded 561 times
- performance.log
- (882 Bytes) Downloaded 613 times
These are not the type o log files to which I am referring. Batch systems usually add a file (either in RESU/<run_id> or SCRIPTS, depending on how you submitted the file, with a name containing the job number, and extension .out and .err).
Also how do you submit the job ? What does your runcase (including the batch header) look like ?
Files directly from the batch systems are, in my case, with extension .e1385884 and o.01385884 which are empty and I have not attached.
Anyway I solved the problem by adding mpirun at the command to the binary cs_solver in run_solver. I called then the run_solver to the batch script (see it attached).
It looks like the cs_solver by default runs in serial when invoked on their own..
FA
FA
- script_parallel.txt
- (206 Bytes) Downloaded 614 times
Maybe you can automate this better by defining the mpiexec command choice in the post-install (code-saturne.cfg), since it seems the automatic/default values do not sem to be adapted to your system.
Details on your system (OS version, mpi library version, and current code_saturne.cfg file, ans summary file) could help us improve the default detection (but SGE is always a mess, with a difficult to automate syntax, so I am not surprised)
