Hello!
Can everybody give me a tip how to solve the following error (which I encountered by executing ./runcase from .../SCRIPTS) ?:
Code_Saturne
Version: 5.0
Path: /usr/shared_apps/packages/code_staurne-5.0.4-gui
Result directory:
/scratch/hpc/25/attene/CS_wave_loads/73/3.62/RESU/20180711-1500
Preparing calculation data
Preprocessing calculation
/usr/shared_apps/packages/code_staurne-5.0.4-gui/libexec/code_saturne/cs_preproc ess: error while loading shared libraries: libiomp5.so: cannot open shared objec t file: No such file or directory
Error running the preprocessor.
Check the preprocessor.log file for details.
Error in preprocessing stage.
Saving calculation results
Best
FA
error in cs_preprocess
Re: error in cs_preprocess
How was the code installed ? It seems you need to load some environment for ir to work.
Thank you for your answer
It was installed at the cluster of the university (Lancaster UK) where I am working; I have just written to them to know more information about it. I will let you know soon..
regards,
FA
regards,
FA
