Jacobi: error (divergence) solving for k
HBELG
Post by HBELG »
Hello everyone,
I would like to know if anyone had this kind of error, I had it after 5hours and 46 minutes of calculations:
../../../../src/code_saturne-5.0.7/src/alge/cs_sles_it.c:4932: Fatal error.
I have attached the listing file below
Thanks a lot for any answer,
listing.txt
(29.82 KiB) Downloaded 370 times
Re: Jacobi: error (divergence) solving for k
You case is probably diverging, but it seems you reduced the logging (listing) output frequency, so we do not have details about intermediate time steps.
Could you re-run your computation with listing output frequency set to 1 ?
HBELG
Post by HBELG »
Thanks for your answer, and as requested here is the listing with an output every 1 step in the attached file, (and the error file).
listing.log
(29.82 KiB) Downloaded 372 times
error.log
(127 Bytes) Downloaded 380 times
It still seems the output frequency is different than 1 (I see NTLIST = 90) in the listing.
Check again under "calculation control/Output control/Log frequency" in the GUI (and check you do not have a setting which overwrites this in user source files if present).
Could you also attach your XML file ?
HBELG
Post by HBELG »
This calculation is for the same game, and for 10 iterations, I simplified, more my geometry, but still get the same ERROR, I have already generated with the same characteristics of mesh for other geometry and it works well, so I don't get this "Jacoby error",
I have attached files requested int he last reply,
Thanks for any answer, best regards
Houda
listing.log
(119.07 KiB) Downloaded 367 times
error.log
(909 Bytes) Downloaded 350 times
setup.xml
(190.25 KiB) Downloaded 342 times
Your CFL number is already very high at the second iteration, so you probably have a much too large time step. There are also warnings about gradient non-convergence (a mesh issue) so using a least-squares gradient reconstruction (instead of iterative reconstruction) might help here.
