Hello.
I need any help with use module for weakly compressible or related.
1 - Where I can to found this sub-routine?
2 - This compressible effect is used for change the presion or only is affected for temperature?
2 - do is this sub-routine can be usefull to simulate the compression water on water hammer phonomenon? (for the high pressure change and with water how fluid)
For 1st question I believe that this sub-routine is cs_user_boundary_conditions.f90, based on compressible example, but I isn't sure that this. Other question I don't know nothing.
Thanks!
A question with weakly compressible characterist.
