Problems when converting the result to MED format
Posted: Fri Mar 09, 2018 9:10 pm
Hey there,
I need help, I've been tortured by this problem for quite a long time and here is my problem.
I'm trying to running the case "3Ddisks" which is a test case provided by SYRTHES itself, and none of the configuration was changed.
The version that i used is V.4.3. which has been pre-installed in CAELinux 2017.
I used the command "source" before open the GUI program and the calculation itself execute with no error:
BUT when i was trying to converting the result file to MED format, the following error appears ( Segmentation fault (core dumped) ):
when i trying to use the function "SYRTHES4MED30" alone, it gives me a error as follow:
However, when i trying to convert the result to .Ensight.case file, it works with no problem:
Why does this happen?
How am I suppose to fix this problem?
I would like to have a .med file, because i want it serves as an input file for Salome meca for further simulation.
Cheers,
Start SYRTHES preprocessing
Updating the mesh file name..
-> OK
Start SYRTHES computation
Execution of SYRTHES..
-> number of processors for conduction = 1
***** Successful execution ***** Code: Select all
Post-processing..
.syrthes --> med..
--> /opt/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4med30 -m "/home/sss/Documents/tests/cas_3disks3d/syrthes/../mesh/3disks.syr" -r "/home/sss/Documents/tests/cas_3disks3d/syrthes/resu1.res" -o "resu1.med"
.syrthes --> med..
--> /opt/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4med30 -m "/home/sss/Documents/tests/cas_3disks3d/syrthes/../mesh/3disks.syr" -r "/home/sss/Documents/tests/cas_3disks3d/syrthes/resu1.rdt" -o "resu1_rdt.med"
Error while post-processing result files.
Stop Syrthes execution.
SYRTHES4MED30
SYRTHES --> MED INTERFACE
Transform SYRTHES results files to MED format
Read Syrthes geometry (head)...
Dimension 3
Dimension of elements 3
Number of nodes 23667
Number of elements 120722
Number of elements of bound 14088
Number of nodes per element 4
Read Syrthes geometry (coordinates)...
--> End of Syrthes nodes coordinates read
Writing MED coordinates... ok
Read Syrthes geometry (elements)...
--> End of Syrthes connectivity read for elements
Post-processing..
.syrthes (.res) --> ensight...
--> /opt/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/sss/Documents/tests/cas_3disks3d/syrthes/../mesh/3disks.syr" -r "/home/sss/Documents/tests/cas_3disks3d/syrthes/resu1.res" -o "resu1"
.syrthes (.rdt) --> ensight...
--> /opt/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/sss/Documents/tests/cas_3disks3d/syrthes/../mesh/3disks.syr" -r "/home/sss/Documents/tests/cas_3disks3d/syrthes/resu1.rdt" -o "resu1_rdt"
-> Ok
Cheers,
