torque coefficient
yany
torque coefficient
Post by yany »
Hello everyone.
I output the force on the blade of turbine in X and Y direction as well as the value of the torque on the blade. However, when I calculated the torque using the force, the result didn't match with the torque output. I'm wondering why did this happened? (the force in Z direction is 0).
Thank you very much.
cs_user_extra_operations.c
(13.35 KiB) Downloaded 402 times
Re: torque coefficient
Is the result close or completely different ?
yany
Post by yany »
Yvan Fournier wrote:Hello,
The result is completely different.
Regards, Yan.
It is difficult to help you if you do not provide more details. Which values do you obtain ? How do you compute the torque from the force in your case ?
Did you visualize the force distribution on the walls (stresses surface variable) ?
