torque coefficient
Posted: Mon Aug 07, 2017 8:34 pm
by yany
Hello Everyone,
I' m working on the simulation of wind turbine and I need to monitor the torque(moment) coefficient of one blade to the central axis in every time step. How can I achieve that in code_saturne? Thank you.
Yany.
Re: torque coefficient
Posted: Mon Aug 07, 2017 11:34 pm
We need to add a function to do this, but in the meantime, you should activate postprocessing output of boundary stresses.
You can the integrate the torque based on those stresses either by looping over selected faces in the cs_user_extra_operations user function, or in a separate postprocessing tool such as ParaView.
Posted: Tue Aug 08, 2017 11:16 am
by yany
Yvan Fournier wrote:Hello,
Thanks for your reply.
The postprocessing output of boundary stress can be activated by GUI or other ways?
Now I 'm using the turbomachinery module to simulate the turbine. I found some information about Turbomachinery dedicated postprocessing functions (cs_post_moment_of_force, cs_post_turbomachinery_head) . I'm wondering if these could help me get the lift and drag coefficient and moment coefficient I need?
Thank you.
Yany.
Posted: Tue Aug 08, 2017 10:13 pm
by yany
I searched the information related to the turbulence module on Code_Saturne documentation and found some functions for calculating the moment of rotor(but I'm not sure).
Can I add them to the cs_user_extra_operations.f90 to get the postprocssing result I need?
Thank you very much.
Yany
Posted: Wed Aug 09, 2017 1:24 am
Ys, you are correct. I had forgotten about the recent additions of "utility" functions found in src/examples/cs_user_extra_operations-turbomachinery.c, also described here: http://code-saturne.org/doxygen/src/turbomachinery.html.
The moment of force should be exactly what you need.
Posted: Wed Aug 09, 2017 11:38 am
by yany
So sorry to bother you again. But I cannot find the file src/examples/cs_user_extra_operations-turbomachinery.c in Code_satune 4.0.5. Another question is that how can I use that file? Do I need to add the related functions to the cs_user_extra_operations.f90?
All the best, Yany.
Posted: Wed Aug 09, 2017 1:32 pm
These are new functions in version 5.0. They did not exist in version 4.0, so you need either to adapt the code from src/base/cs_post_util.c in version 5.0 to your user functions, or upgrade to version 5.0.
I recommend 5.0.
Posted: Wed Aug 09, 2017 3:31 pm
by yany
I recommend 5.0.
Thanks a lot. I have installed version 5.0 and found the file cs_user_extra_operations turbomachin
ery.c in SRC/EXAMPLES.... Could you please give me some suggestions on how to use this example file in my case?
Yany.
