CS5 & syrthes
Posted: Fri May 12, 2017 11:51 am
Dear All,
I was wondering if CS5 still supports Syrthes4.3 coupling?
I seem to have a strange problem as I currently can no longer use CS with syrthes coupling.
Every time I try to run I seem to get strange communication errors such as:
Also, CS5 works fine on its own, and the same goes for syrthes, so I'm a bit puzzled.
I also had previously the coupling working but I haven't tested it in a while, so I'm not really sure where things went wrong.
Thank you very much for any input,
Kind Regards
Filip
I noticed is that CS5 calls cs_solver version 4.2, is it an intended behaviour?Application "fluid" (Code_Saturne 4.2.0) syncronized with status flag 0,
which does not specify a known behavior.
Kind Regards
Filip
