Result display problem
Posted: Thu Aug 18, 2016 9:46 am
by amir
I am using Code_Saturne 4.0.4 on a Batch system.
There are some days that I have a rather strange problem on one of my cases.
The problem is related to the result folder display where any of the calculations in this case has not listing, postprocessing, monitoring and checkpoint when the simulation runs without problem.
I tried to create another case but the result was the same.
I do not even know if it is a code problem or server one, as we had a power failure on server about two weeks ago.
So apologize if it is not really related to the other topics but any reply from you could give me a clearer idea about this issue.
The case which I usually obtain with this problem is attached.
Many thanks in advance
Amir
Re: Result display problem
Posted: Thu Aug 18, 2016 2:08 pm
This should be in "usage", not "discussion".
Did you check the temporary execution directory ? The path of this directory should be listed near the beginning of the batch log output file.
Also, in case of driver/hardware issues, the error messages should also appear in a batch log output or error file.
