I am running a coupled simulation, I made the simulation for the fluid and the solid separately and now I'm trying to couple them, but I get the following error in the fluid directory:
cs_syr_coupling.c:937: Fatal error.
At least 1 SYRTHES coupling was defined for which
no communication with a SYRTHES instance is possible.
1: 0x7fcb7252ece5 <cs_syr_coupling_all_init+0xb05> (libsaturne.so.0)
2: 0x7fcb72469b2b <cs_run+0xfb> (libsaturne.so.0)
3: 0x7fcb72469922 <main+0x112> (libsaturne.so.0)
4: 0x7fcb6fbeeb15 <__libc_start_main+0xf5> (libc.so.6)
5: 0x4008e9 <> (cs_solver)
Any idea?
Andrea
Code_Saturne/Syrthes coupling
- listing.txt
- (25.61 KiB) Downloaded 374 times
Re: Code_Saturne/Syrthes coupling
It seems you defined multiple couplings, both named SOLID, while you only have one coupled Syrthes computation. You probably need to define only one coupling in the Code_Saturne GUI (use "and" to combine your selection criteria). In case of multiple couplings, the name becomes important, as it must match the Syrthes subdirectory (case) name.
So I have 2 surfaces interested by the conjugate heat transfer:
-in CS GUI I put in the "selection criteria" "8 and 6"
-in SYRTHES in the "References" "16 13"
Is that correct?
I want that 8 interacts with 16 and 6 with 13.
Is that correct?
Yes, interaction only occurs for surfaces "in contact" (or very close), so "and" should work fine here.
I managed to create 2 different directory for Syrthes cases, with different names. Everything seems to work but in practice the calculation doesn't start. From the listing I see that CS tries to create 3 couplings but I put there only two.
I attached the listing and the routine I am using.
- coupling_parameters.py
- (1.26 KiB) Downloaded 377 times
- cs_user_coupling.c
- (3.37 KiB) Downloaded 395 times
- listing.txt
- (26.69 KiB) Downloaded 372 times
Do you also have any definitions using the GUI ? This might lead to multiple definitions.
Thanks!!!
Now it works just fine.
