I would like to use atmospheric chemistry (additionnal model in atmospheric module) in my simulation.
I work on windows 8 (code Saturne V4). I want to simulate NO-O3 reactions with no photolyse (scheme 1 in chemistry model) and compare results with measures.... But it was not working. My results are lower than the measures.
Could you tell me, the chemical reaction in the scheme 1 ( I kwow, there are 4 species (NO/NO2/O3/O3P) and 5 reactions) ?
What is the unit of chemical species (kg/kg, mol/mol or ppm ?)
Thanks.
Ambre
Atmospheric chemistry
Re: Atmospheric chemistry
Not sure the people familiar with the chemistry model check this forum very often. Did you check the theory guide (not sure it contains the relevant info) ?
Your best bet is probably to check the chemistry model in the src/atmo source tree...
You don't have the sources in the Windows version, but you can check rhem in the download / subvetsion access portion of this web site.
