coupling with syrthes failure
Posted: Mon May 30, 2016 1:51 pm
I try to make a modelisation of a heat exchanger but I can't make the coupling of CS and syrthes working.
I wanted to make at first a simple case to have the right parameters for the coupling so I created a simpe water pipe surrounded by water and I want to see theheat exchange.
Here is what the terminal is telling me when I run the case
I have exactly the same error with the two fluid domains.
I don't have a Clue where it's not working.
the mesh between the faces are the same for the coupling.
Coupling execution between:
o Code_Saturne [2 domain(s)];
o SYRTHES [1 domain(s)];
Code_Saturne
Version: 4.2
Path: /usr
Result directory:
/home/denis/test_syrthes/pipeHX/RESU_COUPLING/20160530-1358
Preparing calculation data
SYRTHES4 home directory: /usr/lib/syrthes
MPI home directory: /usr
Building the executable file syrthes..
***** SYRTHES compilation and link completed *****
Code_Saturne domain eau on 1 process(es).
Code_Saturne domain eau2 on 1 process(es).
Single processor SYRTHES simulation.
Preprocessing calculation
SyrthesCase summary:
Name = tube
Data file = tube.syd
Update Data file = True
Do preprocessing = True
Debug = False
Case dir. = /home/denis/test_syrthes/pipeHX/tube
Execution dir. = /home/denis/test_syrthes/pipeHX/RESU_COUPLING/20160530-1358/tube
Data dir. = /home/denis/test_syrthes/pipeHX/tube
Source dir. = /home/denis/test_syrthes/pipeHX/tube
Post dir. = /home/denis/test_syrthes/pipeHX/RESU_COUPLING/20160530-1358/tube/POST
Conduction mesh dir. = /home/denis/test_syrthes/pipeHX/MESH
Conduction mesh name = tube.syr
Total num. of processes = 1
Logfile name = syrthes.log
Echo = True
Parallel run = False
SyrthesParam summary
Param file name = tube.syd
Conduction mesh name = /home/denis/test_syrthes/pipeHX/MESH/tube.syr
Radiation mesh name = None
Result prefix. = resu1
Restart = False
Coupling = True
Interpreted functions = False
Start SYRTHES preprocessing
Updating the mesh file name..
-> OK
Starting calculation
with errorcode 1.
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
with errorcode 1.
with errorcode 1.
mpiexec.openmpi detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[55125,1],0]
Exit code: 1
Either Code_Saturne or SYRTHES may have failed.
Check Code_Saturne log (listing) and SYRTHES log (syrthes.log)
Saving calculation results
Error in calculation stage.I don't have a Clue where it's not working.
