LES: SGS Viscosity at previous timestep
philippks
Post by philippks »
I would like to retrieve the SGS viscosity from the previous timestep in LES mode. The variable ivista doesn't seem to be calculated in LES, and field_get_val_prev_s is also not working for ivisct. Do you have any hint how to solve my problem?
Many thanks in advance.
Re: LES: SGS Viscosity at previous timestep
Could you provide the recommened usage info (i.e. at least the version you're using) ?
Yes, in src/base/varpos.f90 (in the code sources), you'll find:
if (iviext.gt.0) then
  nproce = nproce + 1
  ivisla = nproce
  call field_set_n_previous(iprpfl(iviscl), 1)
  nproce = nproce + 1
  ivista = nproce
  call field_set_n_previous(iprpfl(ivisct), 1)
endif
Removing the test on iviext should do the trick.
For user code, the cleanest solution would be to add:
nproce = nproce + 1
ivisla = nproce
nproce = nproce + 1
ivista = nproce
In you user subroutines, in a case's SRC/cs_user_parameters.f90 in the usipsu subroutine. If this fails, modifying varpos.f90 should work.
philippks
Post by philippks »
Many thanks for your fast reply! My CS version is 4.0.4. Both methods work, however, it seems that in LES mode, ivisla and ivista are not created somewhere else in the source code. (I grepped for ivista and only found it for RANS turbulence models.) Thus, I only used the parts
Thanks again,
Philipp
