View of initial conditions
quarian_engineer
Post by quarian_engineer »
Hello dear users,
is there a possibility in code_saturne to view the initial conditions in Paraview, like this results.case?
Thanks in advance
S.
Re: View of initial conditions
There is not currently a "standard" way to do this (this is a longstanding request on the bug-tracker, but I planned to unify the probe and profiles mechanism with the visualization output first, so have not doen it yet).
If you run the code in "zero time step" mode (under the GUI, in "Numerical Parameters/Time step"), you might obtain the required output (I have not checked this recently).
quarian_engineer
Yes it worked :) Thanks.
