Page 3 of 3
Re: import meshes from OpenFOAM
Posted: Wed May 25, 2022 1:14 pm
by MatthieuM
Thanks for your help. After some debugging, it appears that concerning the id of the generated med file, it is necessary to use the med library type "med_idt" instead of "int" as was the case in the existing tool. As you mention, this "med_idt" type probably depends of the MED library build concerning the integer sizes.
Now the tool works fine. I join the 2 files I modified from the initial tool available on
https://github.com/mortbauer/foamMeshToMED. As a reminder if there are interested people, my configuration is :
- Ubuntu 18.04 LTS
- Openfoam 9
- MED 4.1.0
- hdf5-1.10.6
Matthieu
Posted: Fri May 27, 2022 2:22 pm
Thanks for the feedback. And yes, I confirm that med_idt is can be 32-bit or 64-bit depending on build options (and did not exist/was equivalent to med_int in older MED versions).
Since FoamtoMed does not seem to be maintained anymore, but some users reported similar issues (
https://github.com/mortbauer/foamMeshToMED/issues/3), I guess one of us may need to fork the tool to make the update available. If you handle it, that is perfect for me. Otherwise, I'll try to do it in the coming weeks.
Posted: Tue May 31, 2022 10:50 am
by MatthieuM
After checking, it seems I missed a recent fork concerning issues I just mentioned and solved (
https://github.com/robertodavia/foamMeshToMED), my apologies about that. It's indicated for OpenFOAM 8, but it's perfectly functional with OpenFOAM 9 + configuration I previously mentioned, and similar to modifications I made. Consequently I don't think it's necessary to create a new fork at this time.
To finish and just for information, I also noticed this foamMeshToMED tool apparently doesn't work with the OpenCFD release OpenFOAM v2112 (some functions are missing), it is necessary to use the openFOAM foundation versions (I don't know concerning the foam-extend fork).
Matthieu
Posted: Wed Mar 29, 2023 1:42 pm
by finzeo
Is there any news regarding this topic?
I suspect that I am having problems working with foamMeshToMED + OF v1812 (I need to use the com version because of the extra features it has to generate the mesh, over the org version)
Posted: Thu Mar 30, 2023 10:44 pm
No, this is in our TODO/wish list, but with many things higher on the list, so we have not worked on this.
I just answered you other post (related) with a few suggestions:
viewtopic.php?f=2&t=3099&p=17007#p17007
