Problem of heavy fuel oil combustion in 4.0.3
yhuang
Post by yhuang »
Hi, everyone
when I use the model of heavy fuel oil combustion, the results was not right. The temperature was significantly smaller than the expected?
The fuel was kerosene. The boundary "Inflow" was pure air, and "fuel" is pure kerosene.
The "dp_FUE" and "cs_user_boundary_conditions-fuel.f90" were below. Was it right?
Thank you very much!
Yuan huang
src.zip
(3.97 KiB) Downloaded 659 times
Re: Problem of heavy fuel oil combustion in 4.0.3
Without the other recommended information, it is hard to determine what is wrong.
Also, fuel combustion has been unused outside the scope of validation for a while, so I would not be surprised it there are bugs, but the provided info is not enough to tell if the issue is due to a bug or your setup.
