0-equation turbulence model
Posted: Wed Nov 18, 2015 1:47 pm
by CTrinca
I need to implement a simple 0-equation turbulence model, where the turbulent viscosity is taken to be proportional to the streamwise component of the velocity. In my plans, I wanted to do so by modifying the molecular viscosity in usphyv and running the calculation as if it were laminar. Is this the correct/best way to proceed?
Thanks to anybody answering.
Cosimo
Re: 0-equation turbulence model
Posted: Thu Nov 19, 2015 5:31 am
This is probably the simplest way to do it, and probably should work, but for a cleaner approach, adding a model in src/base/tridim.f90 (at the same level as turbke, turrij, ....) might be better.
I'll let the turbulence specialists answer that one in more detail...
Posted: Thu Nov 19, 2015 7:46 am
by Martin FERRAND
Your proposition is the best. Do not forget to activate a variable molecular viscosity.
Best Regards
Martin
Posted: Thu Nov 19, 2015 1:38 pm
by CTrinca
Thank you very much for your answers.
I have implemented the model in the way you suggested. It compiles, at least, but I am having convergence problems that I did not have before I introduced it. I am now trying to find out what is actually happening.
Thank you again nonetheless
Cosimo
