Boundary condition at inlet
Posted: Wed Oct 21, 2015 1:01 pm
by quarian_engineer
Hello dear users,
I am confused with the definition of boundary condition at inlet; my flow should be in the negative direction of the z-axis, does it mean that I define it as "6 m/s" normal to inlet and as direction - specified coordinates with Z = -1 or is it enough to define just "6 m/s" normal to the inlet?
Kind regards
Re: Boundary condition at inlet
Posted: Wed Oct 21, 2015 11:14 pm
Positive values of normal flow means incoming flow.
But for simple cases like this, instead of waiting for a an answer on the forum, experimenting with the code on a small/simple mesh is the would have given you a quicker answer (at worst, the code will crash, but it won't bite you).
Posted: Thu Oct 22, 2015 1:26 pm
by quarian_engineer
Thank you. Unfortunately, my code crashes anyway. I'd like to know, which BC were in any case right to find the real error a bit faster
Posted: Thu Oct 22, 2015 1:33 pm
OK. If your code crashes anyways, don't forget that there's a section with recommendations on how to debug your case in the documentation section of this web-site:
http://code-saturne.org/cms/documentation/BPG
Hoping it helps (if it doesn't, you can post details providing the info recommended on this forum, but that means iterations between different people, which takes longer).
Posted: Wed Oct 28, 2015 11:43 am
by quarian_engineer
Thank you for this link, I didn't know that it exists. Now I have pretty much things to test. ;D
But I'm still confused with my boundary condition. I have one complex case which isn't working and one very simple case which I'm using to test different settings/solvers etc. before run it all on the complex case.
So, I set BC at the inlet in both cases just to 1 m/s with normal direction to the inlet; the simple case gave me only positive values in the velocity distribution as result (as I expected) and in the complex one all values of the velocity were negative. Why is this happening? The both flow domains have the same positions of the inlet, outlet, walls, etc.
Selora
Posted: Wed Oct 28, 2015 8:33 pm
by Martin FERRAND
Could you provide some screenshots to understand your problem?
Martin
Posted: Thu Oct 29, 2015 11:39 am
by quarian_engineer
Yes, sure.
This is my "complex" flow domain:
http://venus.workupload.com/image/Yj5UytDQ it is only the one third of the actual flow domain because of a symmetry. There is a turbine blade in the middle of it.
This is my simple case which is similar to the turbine flow domain:
http://venus.workupload.com/image/ORUI3tQj But there is nothing in it, so this is supposed to be a wind channel.
Inlet should be located on the left side, approximately at the coordinate z = 1, and while making pictures I found what I did wrong - accidentally I permuted inlet and outlet in the second case
. Now all results look similar to each other. Velocity distribution is positive in both cases. (The question is - whether is it correct... Do you think, I should get the negative values because the flow goes in the negative z-direction? To get positive values I set BC at the inlet to -6 m/s)
Even though, the turbine simulation crashes after some iterations (divergence of velocity & pressure). I suppose the last thing that I can change is to test some different settings for the solvers; I don't believe that the simulation crashes because of mesh issues, it looks kind of perfect and I get not a single error after "check mesh".
Thanks anyway
Posted: Thu Nov 05, 2015 7:39 pm
by Martin FERRAND
As a convention, we take negative mass flux for inlets (because as a convention, the normal to the boundary is outwarding) so no matter of the direction of z.
Concerning your crash, what I advice is to extrude your mesh next to the outlet (because the pressure BC is supposing that the mesh is extruded). Otherwise, you could impose a negative inlet at the outlet, that may also work (at that time, be careful to give the same mass flux between in and outlet otherwise the pressure solver will crash in one single iteration)
Martin
