Problem running CS 4.0.2 on windows 7
Posted: Wed Aug 26, 2015 5:05 pm
by jb_l
Hello
I'm trying to use Code_saturne on Windows 7 64 bits
I've tried to run the tutorial case "Shear driven cavity"
Study directory structure has been created with "New file" in the GUI
The check mesh process run and result is ok.
But when firing calculation, the following error message appear :
File "C:\Python27\lib\site-packages\cx_Freeze\initscripts\Console.py", line 27, in
File "bin/code_saturne", line 76, in
File "lib/python2.7/site-packages/code_saturne\cs_script.py", line 88, in execute
File "lib/python2.7/site-packages/code_saturne\cs_script.py", line 150, in run
File "lib/python2.7/site-packages/code_saturne\cs_run.py", line 304, in main
File "lib/python2.7/site-packages/code_saturne\cs_case.py", line 1764, in run
File "lib/python2.7/site-packages/code_saturne\cs_case.py", line 1504, in prepare_data
File "lib/python2.7/site-packages/code_saturne\cs_case_domain.py", line 715, in preprocess
cs_case_domain.RunCaseError: Preprocessing stage required but no mesh is given
As I understand, no mesh is found...
The file "Cavity_mesh.med" is in the directory "MESH" of the Study
And in the Calculation environment/Mesh selection :
Under Meshes tab :
Import mesh selected,
Local mesh directory ..\MESH
List of mesh as in the tutorial
summary file of the run is attached
Does anybody has an idea??
PS : Many thanks for porting Saturne on Windows. Waiting that for...7 years maybe...
Re: Problem running CS 4.0.2 on windows 7
Posted: Wed Aug 26, 2015 5:34 pm
by jb_l
After checking, it appear that the field "Numbers" under Calculation environnement| Meshes selection| List of meshes wasn't filled up.
I've adding "1" in this file and restart calculation.
But there is still some error in preprocessor execution :
../../../preprocessor/appli/ecs_cmd.c:1123: Fatal error.
Option "--num " is not recognized.
Error in preprocessing stage.
Does anybody knows where is the preprocessor.log file?
Any idea about this issue?
Listing file of the calculation is joined.
Thanks a lot by advance
Posted: Thu Aug 27, 2015 6:16 pm
Your first error is probably due to not having saved the "runcase" before running the case.
Your second error is not related: you have found a small bug, for which I have the fix (which will be in 4.0.3, which we'll probably release near mid-september). I'll commit and merge it in a few days (I'm out of office this week and next week).
In the meantime, if you remove the "1" where you added if in the "Numbers" zone for mesh selection, your computation should run OK.
Posted: Mon Aug 31, 2015 9:03 am
by jb_l
Hello
It's now working.
Thanks a lot
