Easy way to determine if point is in fluid domain?
Meskine
Post by Meskine »
Hi everybody,
Is there a simple way to determine if a point (x,y,z) is in the fluid domain ?
For example if we have a fluid domain with obstacles (that could be complex), it is difficult to define conditions based on geometrical criteria. Does a simple test exists to determine if we are in or out ?
Does the function findpt give the nearest nodes even if we are outside the domain border ?
Thank you for your help
Meskine
Re: Easy way to determine if point is in fluid domain?
Currently, findpt will find the closest cell center.
To really determine if a point is inside the mesh, you would need to use the ple_locator_... / fvm_point_location_... functions, which are accessible in the code's C API.
A rewrite of probes using this is planned in the future, but for now, you need to use relatively low-level functions to do this.
The code for the new mapped boundary conditions (in cs_boundary_conditions.c) is probably the simplest example in the whole code using the needed functions, so you may want to take at look at it, in addition to libple/src/ple_locator.h.
Meskine
Post by Meskine »
Thank you Yvan for these informations
Meskine
