About the "floating point exception" error
Posted: Mon Oct 06, 2014 10:01 am
Hello everybody:
This is not an original thread as there are many people posting the same error as it seems to be a error related with several sources which may lead to a common end: a division by zero, and this result may be because of a property calculation, a boundary condition mismatch etc.
Am I right or my guesses are innacurate?
...in that case, as there is not more information rather than the error files, is there any "clue" within the generated error files which may help to find the trouble origin?
My case: an OFA mixing optimization in grate-fired Biomass Boilers. A quite simple simulation (in terms of considered mechanisms) but a highly turbulent phenomena requirement.
I have performed several simulations for a fixed geometry (and a fixed mesh) and a fixed flue gases flow (@ 1200ºC) for several OFA entry conditions (increasing air speed for a fixed temperature of 200ºC) but as higher the OFA velocity inlet is (~80 m/s), the more common the "floating point exception" errors become. The density is the only temperature-dependent variable, but I guess as more turbulent the mixture is, the simulation seems to be more critical, so my solutions has been:
- Increase mesh refinement in OFA mixture zone. (several tries has been performed, from a global refinement to a local high refinement strategy)
- Reduce pseudo-timestep and increase the number of iterarions.
- Solver precision reduction in order to avoid "oscilating" residues during calculation stages. (from 10e-8 to 10e-5)
...but although the simulation reachs a higher iteration, it always stops with a "floating point exception" error.
So ...
a) Is there a suggested robust strategy to face these situations?. I have thought (and tested) the using of a "rough" solution (slower OFA velocity based stable solutions) as an initial solution for the simulation, but no improvements has been founds on the results.
b) Is the Standard k-epsilon turbulence model adequate for MOST of the situations or it could be suggestionable to change it in high-turbulent situations (as this one)?
c) How could the "floating point exception" error files analyzed constructively?
Thanks for your attention.
So ...
