DNS Rayleigh-Benard instability
leguichet
Post by leguichet »
Dear Saturne users,
Inspired from the tutorial on line "Heated square cavity flow", I trying to set up a test case for Rayleigh-Benard instability. I would like to obtain the instability onset procedure through the unsteady solver.
I made a 2D mesh, with 1m high (in x), 8m long (in y), and 0.01 m thick (y). The periodic condition by translation is imposed in the x direction in the "mesh selection" part. The bottom wall is set to 303.15K and the top wall is set to 293.15K. The Boussinesq approximation is implemented with a variable density with respect to the temperature as in the tutorial.
However, I can not obtain the convection rolls at Ra=2000, whereas the instability threshold is known at 1708. So I am wondering if and how we can do some DNS with code_saturne? The time step dt=0.1 too large for a mesh dx=0.01? Or the mesh is fine enough? or something wrong with my setup? If somebody can have a look at my case, that will be very helpful.
Thank you very much!
Zhenlan
Cavity.py
(5.31 KiB) Downloaded 433 times
RB.xml
(7.77 KiB) Downloaded 394 times
cs_user_physical_properties.f90
(82.31 KiB) Downloaded 434 times
Re: DNS Rayleigh-Benard instability
In any case, for DNS-type computations, you will need a CFL around 1, so you need to adjust your time step so that max (velocity*time_step / cell size) <= 1.
Some people have done DNS-type computations with Code_Saturne in the past, but I am not sure what options they used. I have never seen the results, but heard they were quite OK (of course, the code is slower than a specialized DNS code). It might be useful to switch from laminar to LES, so that you move to a second order time scheme (otherwise, you can also force the second order scheme setting the ischtp keyword to 2 in cs_user_parameters.f90 / usipsu.
leguichet
Post by leguichet »
Dear Yvan,
Thank you for your reply.
In SRC/REFERENCE/cs_user_parameters.f90, I found the subroutine usipsu, but there is no option for ischtp. Could you tell me in which file it is?
I am using the version 3.0.5
Zhenlan
Yvan Fournier wrote:Hello,
All you need is to add
ischtp = 2
somewhere in usipsu (many of the keywords described as "advanced" in the user documentation do not have a "resident" example in the reference usipsu).
leguichet
Post by leguichet »
Thank you for your reply. Here I give some feedbacks and pose some new questions.
I indeed observed the Rayleigh-Benard cells by runing code_saturne. In fact, we need the width D between the plates is set to about 10mm for air, if the \beta is set to 1/T_0 as suggested in the tutorial. However, if we set D=1m, and varying \beta as function of D, \mu, g, etc, as suggested in the tutorial, we can not obtain the Benard cells. The explanation seems about the length scale for diffusion, I am not totally sure.
So my question is about, what is a proper way to implement the Boussinesq approximation in Code_Saturne? If it is possible to do it in a non-dimensional way? Thank you.
Merry Christmas
Zhenlan
ischtp = 2
leguichet
Post by leguichet »
Dear Yvan,
I have a further question about the temporal second order scheme.
For the Rayleigh-Benard convection, we have the base flow, an analytical solution:
u = 0; v = 0; w =0; linear profile for temperature.
I use the cs_user_intialisation.f90 to initialize this field.
The table rtp can be set, but rtpa is not allowed to be set.
So how do the code to intialize the flow? since we need two previous time steps to do the first calculation.
For instance, I found there is a small oscillation in the beginning of the simulation. It seems that some random noises were introduced for the velocity field (maybe not verify the divergence zero condition), so it takes a short time to reach the base flow?
By the way, for the tutorial of differentially heated cavity, I have a comment about the physics.
The tutorial is supposed to use the Boussinesq approximation, so the density of air should be constant. The right way to this is to introduce a source term as the Buoyancy force.
In the tutorial, the density is considered as a variable depending on the temperature. It is not the Boussinesq approximation. That is why I could not capture the onset of first instability at Ra=1708 correctly, when I started the study.
Unless, for the Non-Boussinesq case, the viscosity and conductivity should also be considered as temperature depended variables. See the paper by Le Maître or by Suslov & Paolucci
http://perso.limsi.fr/olm/biblio_dwnload/siam_0mach.pdf
http://eprints.usq.edu.au/355/1/Suslov_Paolucci_AO.pdf
I think that it is better to correct this point in the tutorial file.
Zhenlan
ischtp = 2
Did you try setting rtpa anyways ? Did the compiler complain, or the code overwrite rtpa with rtp ?
I am not the "time scheme" specialist for Code_Saturne, so I'll let colleagues pick up from here... I'll remind them to take a look at your post early next week.
leguichet
Post by leguichet »
I tried to set rtpa, it gives the following errors during the compilation
Boussinesq4/SRC/cs_user_initialization.f90(130): error #6917: This array with adjustable declarators must be declared a dummy argument. [RTPA]
double precision dt(ncelet), rtp(ncelet,*), propce(ncelet,*), rtpa(ncelet,*)
compilation aborted for /Boussinesq4/SRC/cs_user_initialization.f90 (code 1)
rtpa is not an argument passed in the function
subroutine cs_user_initialization &
( nvar , nscal , &
dt , rtp , propce , propfa , propfb )
