Shear stress in user subroutine.
anderse4
Post by anderse4 »
I am trying to implement a model that requires that I have access to the shear rate in each cell in laminar low. I can see how this can be found if I were using turbulence modeling, but I cannot find it for the viscous case. Are the stresses stored in an array or will I have to calculate them manually?
I'm sure this question has been answered before, but many hours of searching have not given me a result. I am also still becoming familiar with the user subroutines, the naming scheme has a steep learning curve. Thank's for your help!
Jacques Fontaine
Re: Shear stress in user subroutine.
Post by Jacques Fontaine »
You have to (re)compute it manually. You can use cs_user_extra_operation.f90 to do this.
You must use gradient function to compute velocity gradient (the gradient function name is dependant of ur Code_Saturne version).
Which version are you using ?
anderse4
Post by anderse4 »
I am using the most recent release 3.3. Thanks for your help!
Jacques Fontaine
Ok.
So you can use something like this to compute velocity gradient:
    ! Decl
    integer          inc   , iprev
    double precision, allocatable, dimension(:,:,:) :: gradv
    ! Code
    allocate(gradv(3,3,ncelet))
    inc = 1
    iprev = 1
    call field_gradient_vector(ivarfl(iu), iprev, imrgra, inc,    &
                               gradv)
anderse4
Post by anderse4 »
Thanks for your help! This subroutine is very convenient, but I do have one question. Does it return the gradient in simulation units or in a normalized format? I ask because for two different velocity fields the magnitude of the gradient tensor is always quite close to one with a much different mean velocity.
Thanks!
Eric
