ALE method on airfoil
Posted: Wed Aug 13, 2014 1:17 pm
I have been trying to adapt the VIV ALE tutorial for use on an airfoil cross section. I am working in version 3.1.3. I have attached my xml file, my mesh and an abridged listings file. I have tried to simply replace the cylinder in the tutorial with an airfoil cross section tied to a spring system which only allows movement in the z direction (up and down).
Tutorial is here: http://code-saturne.org/cms/sites/defau ... action.pdf
I have issues with my grid being too refined for a k-e run and too coarse for a laminar run and I have tried using SOLU as suggested in another forum post (http://code-saturne.org/forum/viewtopic.php?f=2&t=1466) but my simulation keeps failing at the same point with this error:
Incoming flow detained for 105 outlet faces on 400
Warning:
_iterative_scalar_gradient; variable: 1; sweeps: 100
normed residual: 9.9885e+55; norm: 1.4648e+01
Warning:
Warning:
Conjugate gradient [Pressure:0000]: divergence after 1 iterations:
initial residual: 2.1393e+02; current residual: 1.2431e+07
cs_multigrid.c:1230: Fatal error.
algebraic multigrid [Pressure]: divergence after 4 cycles:
initial residual: -1.0000e+00; current residual: 1.2431e+07
1: 0x7fd476403092 <bft_error+0x92> (libsaturne.so.0)
2: 0x7fd476083846 <+0x319846> (libsaturne.so.0)
3: 0x7fd476081da5 <cs_multigrid_solve+0x715> (libsaturne.so.0)
4: 0x7fd47608166f <resmgr_+0x16f> (libsaturne.so.0)
5: 0x7fd4760c13bf <invers_+0x10f> (libsaturne.so.0)
6: 0x7fd475f7d719 <resopv_+0x8289> (libsaturne.so.0)
7: 0x7fd475f0b7a1 <navstv_+0x2f61> (libsaturne.so.0)
8: 0x7fd475f9ff5c <tridim_+0x2a2c> (libsaturne.so.0)
9: 0x7fd475de6d04 <caltri_+0x3fe4> (libsaturne.so.0)
10: 0x7fd475dba142 <cs_run+0x8e2> (libsaturne.so.0)
11: 0x7fd475db983c <main+0x14c> (libsaturne.so.0)
12: 0x7fd471238d1d <__libc_start_main+0xfd> (libc.so.6)
13: 0x4007e9 <> (cs_solver)
I am guessing it is something big I am doing wrong. IF anyone could point me in the right direction I would be very greatful!
Thanks in advance!
S
Warning:
Warning:
Warning:
Thanks in advance!
S
