Wavy vortex flow
caste08
Wavy vortex flow
Post by caste08 »
Hello everybody,
I'm working on the Taylor-Couette setup with Code Saturne version 3.0.3. I have succesfully computed for the stable Taylor vortex flow (inner-cylinder rotation set with cs_boundary_conditions subroutine, outer cylinder stationary). For this case a 250,000 element mesh was sufficient.
I am now testing for wavy vortex flow. I set the inner cylinder rotation speed at 19.05 rad/s, which according to the geometry and experiments performed, should result in the wavy vortex flow regime.
I am expecting a periodic Z-velocity component at the monitoring points. After a first transient response, the solution seems to be periodic, but is eventually damped and finally converges to a steady solution with no periodicity. For this case I am using a finer mesh, 1 million elements, a time step of 0.005 and 4000 iterations.
I tested with other angular velocities with the same result, periodicity for a while but converges to a steady solution.
Any ideas on why this happens and how to achieve the periodic solution?
I attach the listing file, compile.log, preprocessor.log, xml file, user subroutines, and the probes_velocityZ.csv and probes_velocityY.csv files.
I attach images of the mesh. It consists of hexahedral elements, 50 in radial direction (finer close to the inner_wall and outer _wall), 100 equidistant elements in axial direction, and 200 equidistant elements in azimuthal direction.
Note: I modified the clptur.f90 file in order to extract the friction velocity and used cs_user_modules and cs_user_postprocess_var to output the wall shear stress.
Thank you for the support,
Carlos
WVF.tar.gz
(1.24 MiB) Downloaded 196 times
Brian Angel
Re: Wavy vortex flow
Post by Brian Angel »
Can you upload the volume mesh that you are using?
Brian Angel.
Brian Angel
Hello Carlos,
One other thing, are you using work that is available in the open literature to test Code_Saturne? If so, can you send me the details of the publication or upload in onto this forum?
Brian Angel.
